주요 콘텐츠로 건너뛰기
Model A1112 / 512 MB or 1 GB capacity
25 질문 전체 보기
My shuffle will not charge, no lights or anything?
The 1st generation unit has had minimal use in the last 2 years, the other day while jogging it cut off, DEAD,. I thought it was the batt but whn i plugged it in no lights, the computer does not recognize anything... I more than likley sweat in the unit!! Help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
The battery gets older - with or without usage
(sometimes is not using worse than using it)
follow this guide and disassemble it, look out for possible fluid damage signs (white/greenish stuff on the components), if there are any signs of a fluid damage - clean the logic board with isopropyl alcohol (>90%) and a soft paintbrush - if there aren't any signs of fluids inside the shuffle - take a multimeter (maybe borrow one) and measure the battery - if it's lower than ~ 3.4V the computer won't recognitze the iPod and would not charge it.
the shuffle has a Li-Po cell - they could die within seconds - especially when they wheren't much in use (deep discharging kills Li-Po cells) - if the cell has 0V - you should get a new one
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Yeah I have an Ipod Shuffle 1st Generation as well. But, I have charged it for 24 hours and there is still no lights, and it won't load on Itunes. It is completely dead but how do I make it charge so that it will work?
Help :/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mikke 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 43
전체 시간: 20,842
