주요 콘텐츠로 건너뛰기
The twelfth and final generation of the Cadillac Eldorado was introduced in 1992 as a two-door coupé.
29 질문 전체 보기
질문 마감됨
air condistioner in car
compressor and/or pullies make noise
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
It is usually one of two things, first if the refrigerate is low and some of the oil and escaped, then the compressor is the actually problem, Usually, by adding a small amount of oil with take care of this. Second, the bearing on the clutch is dry and is about to freeze up on you.
Does the "pulley" make the noise with the a/c on or off or both? It it is both then 2 is the answer if only while the a/c is running then 1 is the problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Have compressor and/or pullies checked by a mechanic
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 987
