주요 콘텐츠로 건너뛰기
Toshiba's Satellite M35X-S114 comes equipped with a 15" LCD display, built-in stereo speakers, and a removable battery.
4 질문 전체 보기
Why won't my computer turn on?
My computer will not power on after pressing the power button. It remains off, even if the power cable is plugged in to an outlet.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Nathan Jansen, start by checking the AC adapter. Use a multimeter and ensure that you have the proper output. If you do, check the DC adapter on your laptop. Make sure that it is properly connected and that you have current going to the board. If you do and it still does not come on, check the power switch flex and make sure that it is working properly.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
@oldturkey03 nice the power switch flex = that is working properly. what is the other swolution can you help me
댓글 달기
This may be caused by a bad power supply. The AC adapter may need to be tested for defectiveness. The output and DC adapter may also need to be checked.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
@Jade Kim, how is this different from the first answer?
댓글 달기
답변을 추가하세요
Nathan Jansen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 310
