주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2014년 4월 업데이트는 새로운 듀얼-코어 i5 및 i7 Haswell 프로세서를 장착하고 배터리 성능을 약간 향상하였습니다.
100 질문 전체 보기
MacBook Air A1465 Display Replacement
Hi there,
I have the MacBook Air 11in A1465. Bought a few weeks back. I've damaged the display by denting the upper case. A thin 2in dent near the glowing apple. This has not cracked the glass but has damaged the LCD/or one of the back layers. I am thinking I need to replace the entire display and will not get away with just the LCD for this kind of damage, but wanted to seek out opinions first. I can send pictures if that helps.
I found this guide and wanted to know if it would apply to the model I have:
MacBook Air 11" Mid 2013 Display Assembly Replacement
Thanks!
Lee
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
So I found this guide as I posted:
MacBook Air 11" Early 2014 Display Assembly Replacement
But still want to ask about whether folks think I need to do the whole display....
thanks!
댓글 달기
답변 2개
Yes that guide will work for you, just be careful disconnecting the LVDS connector and with the straps that hold in the airport antenna cables, they can tear very easily. When reassembling make sure the antenna cables are flush inside and just under the logic board, if they aren't you will have trouble getting the display to fit in properly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Awesome. Thanks Plam. Do you agree I need to replace the whole display with that kind of damage?
Thanks!
댓글 달기
I have LCD issue for the same macbook air, how much does it cost to buy a new one? I called Apple and they are saying they are out of stock for the same, any other source to buy from? Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Lee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 5,662
