주요 콘텐츠로 건너뛰기
The GravityLight is a gravity generated light source that involves the movement of weights to power a LED bulb.
Why do the bags of rocks not move?
I have filled both bags of rocks and the bags won’t move. I tried to empty out the bags and refill them, but that still didn’t fix my problem.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Stripped gears are the likely cause for the GravityLight to become jammed. Since the gears are damaged and cannot mesh properly, the gears will become stuck. The gears will need to be replaced by removing the front panel and the frame. Instructions on how to access the gears can be found in the Internal Gear Replacement guide.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Jamie Forslin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 367
