Why is my trigger stuck?
I have enough charge in my battery as indicated by the green lights on the battery, yet my trigger seems to be stuck. What can I do?
좋은 질문 입니까?
좋은 질문 입니까?
You may either have the direction switch in the middle or there is something stuck inside of the chuck.There may be also a bad contact between the battery and the drill,you can check the voltage coming out of the battery.
해당 답변은 도움이 되었습니까?
Debris may be blocking the path of the trigger. Check for any external debris caught between the trigger and the drill body. If no external debris can be removed, check for internal debris by disassembling the drill.
해당 답변은 도움이 되었습니까?
This may be caused if the direction switch is in the center position, the trigger is locked and the drill will not function.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,659
