주요 콘텐츠로 건너뛰기
Updated Apple TV with second generation A5 processor / Released March 7, 2012
32 질문 전체 보기
AppleTV Remote water damage
Apple TV is great for use in bedroom, until you loose the remote in the sheets and wash it. My remote recently went through a full wash cycle. Found it before putting into the dryer and immediately wiped down and then let rest upside-down and covered in rice for a day. Next day, cleaned the battery area a bit, put in a new battery, and it seemed to work okay for about a day.
Noticed the select button starting to not work (had to really press hard to get any function) but the menu and play buttons worked fine. 48 hours later, the remote is completely dead. Is there a way to fix this? Could not find a teardown or guide for any Apple Remote.
Any help is appreciated, thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
Watch this video:
http://youtu.be/bPkKtxTD6J0
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Good but what Vodka are they using?
댓글 달기
Forget the vodka. Use isopropyl alcohol.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
'Our toddler decided the Apple TV remote would make a good fish tank decoration so after fishing the remote out which had been submerged in water for over 10 mins shook all the water out dried off the remote placed in a zip lock bag of rice removed as much air as possible and let sit 24hrs then plugged the remote in to charge! Works as good as new!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
buy a fire stick for same price as a new apple remote unless u like the crap programs apple tv actually has.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tyler Timpe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 91
전체 시간: 40,811
