주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
squares on the screen after battery replacement
Hello everybody.
I recently got an iphone 5s with a broken screen. I ordered a screen online and replaced it. It worked perfectly well except the proximity sensor that was not switching off when calling.
After a quick search online I managed to find the issue and I decided to order a new battery as well as I though mine was not lasting long.
I received the battery yesterday and opened the phone again, I replaced the proximity sensor and changed the battery of the iphone.
When I reassembled the phone and turned it on, I had some squares displaying on the top of the screen.
I though it was because the display connector was not properly connected, so I disconnected it and reconnected it. When I turned the phone on again, the squares are still showing up.
I took a photo of the screen displaying the square, you can see it here http://postimg.org/image/h7kq92sy3/
According to you, what's wrong ? What should I do ?
Thank you so much for helping me
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
My iPhone 5s can't turn on... after connect the charger there apple symbol appear and after there is black lines and square are appear....so what I do
.... this is software or battery problem tell me answer
댓글 달기
답변 5개
선택된 답변
Hi,
It is either the screen is not connected correctly or it is a faulty LCD, I would try and clean the connectors first with 99.9% isopropyl alcohol, and then reconnect the screen, if this does not work then I would try a new screen. :-)
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
It's the screen. The connector is not fully making contact with its connector. When putting the connector down, run your finger from let to right to ensure all the pins are making the connection. You should hear 2-3 clicks
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Thanks guys. I had the same issue after I did a battery change. I went back in after reading this and found glue debris from the battery was in the digitiser connector.
I pulled out the glue and put it back together. The squares are gone.
Check the connector on the left of the 3. It's long and skinny. If it's not connected properly it can get worse, like heaps of vertical pin stripes.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you for this! Inspired to take the cover off for one last time 6th time) and found a micro speck of dust on one of the teeth of the digitiser connection. Blew it off, pressed all connections back on very hard and bingo - back to full normal screen.
댓글 달기
Look at the touch connector on the screen does it look bent? Like a banana shape slightly? Do u no what I mean?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You mean the connector or the cable ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Chuck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 10
30일 전: 21
전체 시간: 20,797
