주요 콘텐츠로 건너뛰기
MacBook, MacBook Pro 및 MacBook Air에 사용되는 AC 전원 어댑터. 잡아당길 때 안전하게 분리되는 자가-정렬 자성 커넥터를 사용합니다. 1 세대 (2006-2012) MagSafe 충전기는 약간 두꺼운 L 자형 커넥터가 있습니다. 45 W, 60 W 및 85 W 버전으로 제공됩니다.
Change Magsafe adapter to Magsafe2
I have and older Magsafe Adapter from 2009 MacBook pro. It was broken with the general cable issue. I have fixed it, however it's unused now. I can buy Magsafe 2 repair cable to use with my newer macbook but I don't know whether the voltage will fit. I don't want to burn my mac.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
U.S. shipping only companies are not a solution.
I've read on wiki that the voltage (not wattage!) are different. I would like to see whats inside of the original magsafe to magsafe 2 adapter. I don't need the adapter. I was asking whether I can solder the magsafe 2 adapter to older magsafe AC.
댓글 달기
답변 1개
선택된 해법
Your Mac will only pull as much power as it needs. The voltages are the same. The difference is in the wattage. Here's an adapter you may need: http://store.apple.com/us/product/MD504Z...
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
The inner large pins are V+ (14.5 / 16.5 / 18.5 VDC). Measuring with no load will give 6.86 V DC for MagSafe and about 3 V DC for MagSafe 2; the full voltage is provided after a ~40kOhm load is applied for one second.[8]
Hello,
Based on the above answer , it is possible to use a magsafe 60w charger from a1181 macbook 2008 to a newer macbook air 2014 with magsafe 2 , with just this converter (MagSafe to MagSafe 2 Converter - Education - Apple) . Is my guess right?
Savvas. It will work just fine.
댓글 달기
답변을 추가하세요
masterjet 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 977
