주요 콘텐츠로 건너뛰기
The Honeywell Cool and Refresh Mini Tower Fan is a two-speed fan paired with a Febreze scent cartridge that cools the air and helps eliminate bad odors.
The fan blades won't spin--how to fix?
I can hear the motor whirring inside when I first turn it on but it takes awhile for the fan blades to actually start spinning. How can I fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
The fan blades could be damaged. You can replace the blades, or see if there is anything blocking their movement. There could also be a problem with the motor as a whole. Use this guide to check the fan blades and replace the motor.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Armando Jacob Espinoza 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 12,953
