주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
Adding Bluetooth 4.0 card to Early 2008 MBP
Hi -- not very technical, but have followed guides here to install SSD on an early 2008 non-unibody MBP. Was wondering if it's at all possible to put something like a BCM94331PCIEBT4CAX bluetooth card into this unit, so that I can activate Continuity/Handoff on Yosemite. I doubt it's possible, and the needed connectors are probably not even in this old laptop, but thought I would ask. Thanks!
Any other advice or methods of getting a bluetooth 4.0 card installed internally on the MBP would be greatly appreciated. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Review this: Continuity Activation Tool
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
This doesn't seem to answer the question at all.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Well it did back in 2014 ;-}
The site has altered things and the info it offered is no longer there.
This series can't support Hand-off Services
댓글 달기
귀하의 답변을 추가하세요
Hiryu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 1,583
