주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
208 질문 전체 보기
Stripped Screw on Antenna Plate
So just as the description says, when putting one of the hex screws back in on the antenna plate, I over tightened and stripped one of the screws. And when I say stripped, I mean I stripped the threads, the screw just spins now and doesn't hold, it just falls out. Is there any solution for this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Were you able to solve this problem? I'm having the same issue
댓글 달기
답변 2개
가장 유용한 답변
Usually it's possible to grab the screw with a pair of needled nose pliers. If not, you might have to drew the screw out using a drill.
Hope it helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
There's some really cool pliers designed for just this problem!
Screw Extracting Pliers
Screw Extracting Pliers 이미지
상품
$19.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Its not the hex part thats stripped, its the threads female threads that are stripped.
To get it to hold back in place, you can always try using some Loctite or another type of threadlocker. Just don't get the super high strength stuff, or you'll do more damage.
Thats kind of what I was thinking...Guess I'll give that a shot.
Were you able to solve it? I have the same problem
댓글 달기
귀하의 답변을 추가하세요
betts211 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 402
