주요 콘텐츠로 건너뛰기
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
157 질문 전체 보기
X O Triangle and Square buttons not working‏
Hello all,
I am having trouble with my PS3 controller, all X O Triangle and Square buttons are not working. I have taken the unit apart, placed tape between the ribbon as advised elsewhere, but still these buttons simply don't work. The select PS and start buttons are fine however along with the D pad.
Could anyone please advise on how this issue can be fixed?
Regards,
Oliver
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 3개
i have tried resetting the controller through the pin hole on the controller, but it just return to normal. still have problem, however will try to clean it
I took the 4 screws on the back out and-after careful comparison of the 2 sides-I saw that where the #2 top buttons go in (the little assembly) was a bit wobbly on the right side. It doesn't have as clear-cut a fit as the other side. I also saw that #1 on that side was not fitting correctly into the rubber squishy thing. I had to play around with it for a while to get that side to fit in properly. The battery popped out twice, so I had to pop it back in, too. On the first 2 tries at reassembly, I was still getting the "ghost" button pressed--but I noticed that squeezing the 2 halves on the controller together fixed it (my Mortal Kombat player was stuck in a crouched position, blocking). That tipped me off to something not fitting in right, and causing a bulge somewhere. Finally, the numbers 1 and 2 buttons on both sides were protruding out correctly (and evenly, respective to each other). Now, the controller works even remotely--at first, it was only working when wire-connected...and sporadically, at that!
The only inputs that work for me are :
Joysticks and Triangle.
I think its a faulty mob or input sheet
댓글 달기
답변 11개
가장 유용한 답변
Did you reset the controller? There is a small pin hole on the back of the controller.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Andrew,
I have reset the unit already yes, but an still experiencing the same problem.
Cheers
Oliver
I am having the same problems it feel as if it has a faulty response , maybe damaged motherboard or maybe it got wet idk because i let a friend borrow my dualshock for a few days.
When I press O it doesn’t do anything and I’ve tried to reset it but it still doesn’t work
댓글 달기
go to game stop and mabe its something wrong with either the buttons (faulty buttons) or the mother board has some loose solder to the buttons
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I am having the exact same problem. I don't have a solution, but at least we have the exact same problem which means it's a repeating phenomena.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
One more here! X button stuck. I've opened and replace the membrane board but the problem still. I must be something with the hard circuit board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
My problem is when I press X button it function as A and when pressing B it functions as X
댓글 달기
Try putting some rubbing alcohol on a Q-Tip or Toilet paper and rubbing it on the contacts on the motherboard. Normally what happens is over time the conductive material on the back of the membrane rubs off on the contacts creating a barrier preventing the membrane from making contact. Try that and see if it works.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have checked the diagram and these buttons along with R1 and R2 are paired up with a common pin and a resistor, I have the same problem and will try to figure out where is this resistor located and try to change it, will post if succed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi,
Did you ever get an update here? I know it was some years ago, but I'd still like to know the answer! Could you also forward the diagram you have? Thank you :)
댓글 달기
I have problem with my triangle button. One morning when I was going to play GOW I saw water all over my controller and nobody knows how it happens and I was like
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
the only buttons that work for me is the os button and the left analog i need help
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Yeah, even I have the exact same problem, and I need a solution for it ASAP...
I'm having same problem O X ANGLE SQURE R1 and R2 NOT WORKING
댓글 달기
https://youtu.be/75DXKep6-vs
This video helped
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Get Someone to fix it maybe?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I know this is almost a decade late, but maybe it'll help someone in the future. There's a piece of rubber between the circuit board and the pushbuttons that tries to 'push' the electrical contacts of the flexible PCB onto the circuit board. Over the course of years, the rubber loses its bounce. Either replace the black rubber block (approx 3/4" x 3/8"), or I just used masking tape (~6 layers) to increase its thickness. Problem solved.
I use DS4 windows and an online joystick checker to test the controller to make sure that all the buttons were working again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Oliver 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 54
30일 전: 255
전체 시간: 53,366
