주요 콘텐츠로 건너뛰기
The UP! Plus 2 is a 3D printer manufactured by PP3DP for home or professional use and is capable of printing objects of up to 140W x 140D x 135H (mm).
How can I tell if my nozzle needs to be replaced?
I have the same model printer and recently I've been having inconsistent prints, I think the problem is stemming from a clogged print head, but I'm not sure. If I try to extrude plastic before actually executing the print, the plastic comes out fine, but at an angle and not in a constant line as it did when I first received the printer. Any suggestions, or advice?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
Your nozzle is probably jammed with a lot of debris. This happens over time because of static cling. This means the plastic spool is exposed to dust that drifts through the printers working area and tends to transport down to the extruder. This results in not burning in a complete constant line. The quickest solution would be to replace your nozzle or to clean it thoroughly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Spencer Jefferson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 452
