주요 콘텐츠로 건너뛰기
Released on February 25th, 2013. 10.1" Tablet with Android Operating System, ARM Cortex A-7 Quad Core Processor.
Why is my tablet not vibrating?
My device does not vibrate while being "ON".
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
After doing some research, I believe that I have found the answer to my own question.
You should start by checking the tablet's settings. If this does not work, you might have to check the internal wiring of the tablet or check for water damage.
Lastly, if none of the previous steps work, then you probably have a problem with the tablet's vibration switch. To remove the vibration switch click on the Vibration Switch Removal Guide and follow the steps.
댓글 달기
답변 1개
You should start by checking the tablet's settings. If this does not work, you might have to check the internal wiring of the tablet or check for water damage. Lastly, if none of the previous steps work, then you probably have a problem with the tablet's vibration switch. To remove the vibration switch click on the Vibration Switch Removal Guide and follow the steps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gabriel Delgado 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,057
