주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Can the digitizer tearing cause itunes to not detect iPhone
My iphone 5c fell and the screen literally separated from the back of the device. I tried to put it back on and when I did it didn't turn on, then i tried to connected to iTunes but it could not be detected in other words nothing came up. Then i noticed that a little piece from the back of the screen was broken, I started searching for the name of that piece and found out that is called the "Digitizer" or "LCD" I'm trying to get all of my photos since i never used iCloud nor iTunes backup. So my question are: does the digitizer have anything to do with my phone not turning on? Or is there something else wrong that is causing this? And will all my data be erased? Please help by answering these questions
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
Usually, the digitizer will not prevent the phone being recognized by iTunes. If you can not see any type of picture on the screen, then it could be the LCD broke. A simple screen replacement should help and fix the screen and LCD issue. As far as iTunes, try a hard reset and see if that helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Also, replacing the screen should not corrupt your data that is on the phone
So I just need to buy an LCD, because the screen didn't cracked or anything, It just came off.
Also you mentioned that I need to try a hard reset will that erase my data?
댓글 달기
If iTunes isnt reconising it then there's no power getting to the iPhone
The drop could have also damaged the battery
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
And once replacing the battery it won't affect my data in it?
댓글 달기
귀하의 답변을 추가하세요
Ida Mendoza 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 91
