주요 콘텐츠로 건너뛰기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
310 질문 전체 보기
Replace superdrive with SSD, re-use SuperDrive?
Basically in my late 2009 21.5 inch iMac I am planning on replacing the SuperDrive with an SSD (for obvious reasons). However, I would still like to keep the SuperDrive and use it. Is there an external enclosure that I can purchase and put the drive in so I can use it externally? Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Of course - however you need the specs (model number and physical size/port) of your drive to find the right one.
There are many external USB cases available for laptop drives... but the iMac drives could be physically larger so clearly discuss with your vendor before purchase the enclosure you intend to install the drive into.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
John Poulos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 248
