주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
iPhone 4s bootloop after screen replacement
Just changed the screen and the iphone now is in bootloop with the apple logo. The logic board apparently has no problem (I checked with macro lens). I tested the lcd in another Iphone and it perfect work. This is a video with the problem https://www.youtube.com/watch?v=p-dz2SDV...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 5개
가장 유용한 답변
Hi.. I tried a new battery, that's what caused the boot loop (3600mah)..
I fixed this on this phone.. Maybe entirely different cause for some one else..
I noticed a power drain last night after swapping the gutt's to a new shell.. Everything worked fine, so presumed the battery was shot.. So changed it for a high powered battery, which seemed to work fine.. Was about to call the client to say its fixed, one last test.. Boot loop!!
Any way.. After searching lots of posts like this one decided to check for shorts.. Took every thing back out, tested the board while it was unscrewed, but still in place.. It worked!
So screwed it back together testing the boot sequence with every few screws.. The very last connector.. Front facing camera flex! Boot loop.. If I unplug it while in boot loop it works fine and boots up.. So I'm just waiting for a replacement flex and preying the fault is the flex and not on the logic board.. Fingers crossed
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Surely you know that there isn't such a thing as a high powered battery for a iPhone!
The that so called high power battery would probably cause more damage than good.
I would just swap it out for a good proper battery and take no chances
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Is There anyone who can help me?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Apparently Not... I have the same problem - iphone 5 :(
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello have you tried a new battery that would be the first thing til do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Marco Micheli 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 11
전체 시간: 865
