주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why does my battery drain so quickly?
On other smartphones that I have had, the battery would last a day. However, with my Padfone X, the battery only lasts a few hours before it needs a charge. Is there something wrong with my phone? Do I potentially need another battery?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
There are several potential factors that could greatly reduce your battery life. The display uses the most battery power, so to start it is recommended that you turn down the brightness. Also check for any applications that you are not using, but are still running in the background. Close these applications. If you are not using WIFI, you can turn it off so your phone is not constantly searching for a signal. After making these changes, if your battery still
drains quickly, then you may simply have to replace the battery.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
Andrew Smith 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 1,068
