주요 콘텐츠로 건너뛰기
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
Only background showing and not working, not closing?
I have IOS 8. I was reading a pdf on Adobe last night, my charge was gone so it closed. Then I recharged it. I tried opening it. The background appears. no pass word, screen lock. no apps. no up or down manues. nothing. I tried switchin it, does not switch. I pressed the up and down bottons at the same time. apple logo appears, the screen goes blank, after a while, the same background appears. my own background. Ive tried this many times
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 17개
there is also a stage where ipad opens with clock and date showing as it is supposed to, but the screen is extra extra large and does not reduce. I can open the drop down menu above, still extra large.
I tapped the screen with three finger twice, and it opened.
I have the same issue and nothing is working not even rebooting it works :(
same thing hapened to me, what I did is press and hold the power button and home button
Danika, THANK YOU SO MUCH
댓글 12개 더보기
댓글 달기
답변 11개
가장 유용한 답변
Try pressing home button and power button for like 10 seconds should either power off or reboot if powers off turn back on see if fixes if not plug into computer and see if sees it if does may need to reload os if not might be S.O.L.
이 답변이 도움이 되었나요?
점수 13
댓글 12개:
thank you. pressing buttnons like that do not help.
Thank you it worked I was so worried
thank you so much !! life saver
it worked!! yippeee!! thank you so much
thank you so much
댓글 7개 더보기
댓글 달기
I just switched off my phone, then i held the home button and the power button at the exact same time for like 5 seconds then you see a blue screen then it turns black and you will see the apple logo and if it starts its all fine
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you! My phone is saved :)
댓글 달기
Are you able to power the unit off? If so, plug it in, turn it off and leave it sit overnight. At least 8 hours. Sometimes they come back from weird errors like after a timeout and a good charge.
If that doesn't work (don't be surprised if it doesn't), then its time for a restore. Plug the iPad into your computer, hold down the power button for 5 seconds. Then press and hold the home button for 15 seconds while still holding power. Then the "connect to iTunes" should appear. In iTunes, select restore, and let the device wipe and install.
If that doesn't work, please update. Its possible that it could be hardware but I'd bet on a software glitch.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have the same problem. Updated yesterday and it kept freezing up so I shut it down and it loaded with the apple Icon by then only the clock shows. It won't shut down again. Basically the upgrade screwed up my Ipad. Nice going Apple. :-(
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hold power and home button at the same time for ten seconds
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The same thing happened to me
But what can I do to fix it when my home button doesnt work???
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have the same problem too? Anyone can help?
댓글 달기
Can i get help my friend's iphone not working she cant do enithing. Thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
try placing it in some fire. when it burns for about 10-15 minutes then out the fire with some honey and try powering it on with a block of cheese. If that doesn't work power it on with a hammer for 8 seconds then toss if off a cliff, by then it should start working.. working well out of you life, so you can then go purchase a better &&^&^$^ device you stupid @%^$$@$!!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Wtf? (What the flip)
댓글 달기
Hi I learned that if you put ur phone/I pad in the microwave for 5-10 min it will solve that problem thank you for every one who told me that.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
And then eat it. That should work.
댓글 달기
I don't have an answer but I have a question. I have a Zte Whirl that still works but stays on a black screen. Can you help me solve this problem please?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my phone isn't displaying words just the background. what should I do?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
This is not an answer :P
댓글 달기
답변을 추가하세요
nur 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 40
전체 시간: 37,412
