How do you clean it?
The residue of the coffee beans is still in the grinder and hurting its effectiveness.
좋은 질문 입니까?
좋은 질문 입니까?
You can also put in dry white rice and grind it to a powder. Dump that, use a brush or a towel to wipe it out, and the grinder will be even cleaner and ready for something else to grind.
해당 답변은 도움이 되었습니까?
Use a paint brush (about 1/2 inch wide) to brush out the ground coffee, then use a damp paper towel to clean up the fine powder. This method works very well, especially if you use a soft brush. Keep the brush near the grinder and brush out the grinder after each use.
해당 답변은 도움이 되었습니까?
Sweep a clean dry Popsicle stick around the where the blade built up a residue a few times and get your money's worth of coffee. That's where the oily flavor is. Then dump it in the brewing basket. Use the other hints above for a final more thorough cleaning. Go for the flavor first. :)
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 16
30일 전: 67
전체 시간: 13,646
