주요 콘텐츠로 건너뛰기
A professional extra burner. Released in 2008, with model name SB30.
3 질문 전체 보기
Is it acceptable to use large pots or pans?
I am unsure if it would be safe to use pots and pans larger than the heated surface area.
I've done so on a conventional home oven, but I am worried if this hot plate can even handle the bigger loads.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
It won't hurt anything, but it could be not safe as the possibility of the pan/pot spilling over.
The other factor is the transfer of heat will give you a hot area unless your pan/pot is clad with a Copper or Aluminum core to smooth out the hot spot.
You will also need to think about the volume you are heating here. Boiling a large pot of water will take longer and it may not be able to sustain (recover) the boil. Review the BTU's of the heat plate.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
kevin phan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 13
전체 시간: 133
