주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
S4 makes "burning noise" when turning on
Hi,
I recently repaired an S4 by replacing the screen/midframe. I noticed it makes a strange noise kind of like something is burning, on some occassions it does go to the samsung logo then boots back up, so it's like there's a short somewhere. it sounds like it's coming from the charging port but I can't think why.
Now, there's quite a few issues already with the phone. the sim card reader does not work, the volume up button does not work, the wifi and bluetooth does not work and the phone does have warranty until next year.
here's a video of the noise:
https://www.youtube.com/watch?v=9N-ppTj4...
is it possible I could replace this under warranty? I know I have replaced parts but Apple usually will replace the phone if there is still a fault on their end
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 2개
bump help please :(
bumppppppppp
댓글 달기
답변 1개
가장 유용한 답변
It sounds like your external speaker connection is shorting out. Try disconnecting it, reconnecting and see if it still makes the noise.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
okay I noticed the sound happens when trying to make a noise from the external speaker (if you mean the one that attaches to the mid frame) I played a sound and the noise occurs and I pause and it will stop, not sure if it's a coincidence. I also know when the speaker is removed the noise still happens as when I tried another screen and turned it on to test I heard the same noise, the only thing I've replaced in that area is the charging port.
댓글 달기
답변을 추가하세요
Gizmo 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 850
