주요 콘텐츠로 건너뛰기
Small black headlamp made from waterproof materials with an elastic headband.
Why does the strap not fit around my head?
The strap may not fit around your head if the elastic headband has lost elasticity or if you have improperly adjusted the cinches on the headband straps.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Loss of Elasticity
If the headband fails to return to its original length after pulling the strap in opposite ends, the strap has lost its elasticity. You will need to replace the strap with a new elastic strap.
Improper Fit
If the strap fails to secure the device to your head you may need to simply readjust the cinches on the strap to fit around your head. These cinches can both tighten and loosen the strap to fit your head comfortably.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mike 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 913
