주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Weird no-stereo audio issue on headphones only
This is a weird one! On headphones, all audio sounds like it's out of phase, very garbled and muffled as well.
Whilst debugging I found that if I moved the L - R slider in Accessibility just a fraction off the center, audio then sounds fine but with what appears to be no stereo separation. I ran an audio test track and sounds that should be in L or R channels are all coming through both speakers.
Playing through the loudspeaker it all sounds fine but of course this is two channels being fed through a single speaker so may mask the issue?
I'm lost as to what might be the cause here. Is it worth replacing the dock connector assembly perhaps?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Does the problem occur on other headphones aswell? Because faulty or worn wiring to the earbuds can produce this result. If other earphones sound like they should, you're going to have to buy some new ones.
If the problem exists also on other headphones, first clean the dock connector grom any dust, lint and debris and run some paper towel with a drop of 90% alcohol along the contacts (I do this with a toothpick to get the paper in all corners). Then clean out the headphone connector with a piece of paper towel rolled up on a toothpick, again using a drop of alcohol.
If problem persists, take the phone to a genius bar to get it examined.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
DarrenG 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 566
