주요 콘텐츠로 건너뛰기
Samsung Gear Live는 2014년 6월 25일에 Samsung과 Google이 발표하고 출시한 Android Wear-기반 스마트워치 입니다.
The charging cradle broke. Can I replace it?
The charging cradle on my Samsung Gear Live broke. Are replacements available or can it be repaired?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
A chips bag clip works just dandy.
يرجى توضيح أكثر هذا قليلا
댓글 달기
답변 5개
가장 유용한 답변
Had issues with mine, little plastic snap opposite of button side of device.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
In the event of your Gear Live's charging cradle breaking, replacement is your only option. Unfortunately, the charging cradle's design does not facilitate repair, so that option is unavailable.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's worth noting that at this exact moment there appears to be no way to replace it. Samsung will just refer you to Google, and Google says the cradle is "coming soon".. and has for a while now. (https://play.google.com/store/devices/de...)
In short, Gear Live owners are stuck with a charger that easily breaks and can't be readily replaced. Boo.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The easiest way to get around this that I have found with my own broken gear s charger is that you can use a pill bottle. Simply close your watch strap in the locked position place the charger in position, and use a pill bottle to keep enough pressure on it to charge. Make sure the bottle is not too large so that you don't over stretch your band. I did this because I was leary about buying another charger, knowing that the new one would probably break as well in time.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You can get replacement charging cradle easily on Ebay and it works fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Keith Cooper 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 3,802
