Renault M9R A630 has no traction?
No traction in the area of 2000-3500 rpm. Errors in the clip is not. Replace the valve control 7.02256.04.0 turbine and the air flow sensor.
좋은 질문 입니까?
좋은 질문 입니까?
If you have Renault's clip software it will show what's wrong ,it is saying that the valve needs replacing ,looks like its the EMV valves ,if pressure is to low for the torque converter it can't lock up so you won't get drive to the wheels ,the first signed are delays between shifts and then a thump when it goes in gear ,you must reset the software after you change the valves or its back to square one .
Renault automatics were sold on a no maintenance plan if if the fluid needed topping up that's all it ever needed ,said renault ,but the truth is this wrecks the gearbox because the fluid gets contaminated by all of the debris from the clutch packs with theatre steel spacers ,and the bands ,this just keeps being pumped around the system causing damage to valves/valvebody/seals/torque converter/bearings /bushes ect .
Every other auto trans mfg on the planet say change the fluid at 30,000 miles ,renault /Peugeot/citrons are the only ones that don't because they are all part of the French collective ,
These units are designed for dealer service only ,most people don't even know how to check the fluid level correctly because any aspect is shroued in lack of information ,
I have the French PDF on this transmission it shows every aspect right down to customer reports it was ment for training service mechs !
Hope it helps!
해당 답변은 도움이 되었습니까?
This engine is a subject of recalls because of an injector fault thousands are affected this engine is used in a lot of makes and models , the fault seems to be that the injectors size up due to corrosion ,this fault causes other problems if you have one with an automatic transmission on it because its linked to the engines performance ,if its under a warantee or extended one it should fixed for free ,check out the BBC watch dog program Vauxhall/Renault/Nissan van problems and or check out warrantee .com it has big list of recalls !
Hope it helps
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 185
