주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
467 질문 전체 보기
How to re-solder the headphone jack
In iFixit's late 2013 teardown of the 15" macbook pro retina, it was mentioned that the headphone jack is susceptible to breakage because it's now soldered onto the logic board. Has anyone experienced the headphone jack breaking? And how would one go about soldering the headphone jack back on? Can you use the same jack or do you have to get a new one? I haven't seen the jack for the new retina's available for purchase anywhere. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Logic board component soldering takes special tools and lots of practice. Unless you do this for a living you should probably hire a computer repair/small electronic repair shop to do the work.
Depending upon the state of the jack when you notice the problem it may be reused, or need replacement.
If under warranty I'd take the box to apple.
A workaround would be to use a USB audio dongle. . .
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
A USB dongle is what I chose to do. It is ugly and obtrusive but also less than $15 compared to a new $900 logic board or headphone port solder which would be at least $150 if a local repair tech can do it.
댓글 달기
귀하의 답변을 추가하세요
George Valkhoun 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 5
전체 시간: 375
