주요 콘텐츠로 건너뛰기
모델 A1297 / 2.66, 2.8, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
Alternative to Power-On Pads when keyboard is disconnected
So I'm lucky enough. The spill seems so far to have affected just the keyboard.
I cannot boot reliably with the internal keyboard connected. I needed to pull the connector out.
With the keyboard out, I can boot using the power-on pads (by shorting them on the logic board).
For the time being, I'd like to use my macbook with external wireless keyboard and trackpad. This works fine, but I cannot turn the machine on, other than through the power-on pads.
Is there any other way to power a macbook up, with its internal keyboard disconnected?
Possibly, I can skip shutting down altogether, and just go into and out of sleep (since the trackpad will wake the machine up). Still, a proper shutdown before lugging the laptop is nice.
And while I have your attention, and since you have already read all the details, I'm also wondering: Is it possible to run the hardware test/(D)iagnostics through the wireless (bluetooth) keyboard? Pressing "D" during restart does not get me there.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Use energy saver settings to power on the machine at a set time. I agree transporting a running (sleeping) laptop is a bad proposition.
Probably not - but if you connect any USB (doesn't need to be Apple) keyboard that should work.
If this answer is acceptable please remember to return and mark it accepted.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Calaf C 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 113
