주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
White laptop working screen - working normal on external display
Hi,
When I turn on my MBP A1260 the screen is white, nothing is displayed but the white color.
If I connect an external display, I can see my extended desktop and everything seems to work fine (except that I cannot see the content on my desktop as it is on the white screen).
How can I fix the display issue?
Thanks
Axel
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 3개
Unless you work for iFixit, I would suggest changing your sign on name as it is misleading. - vote for the name.
I agree with Mayer, you username is could be misleading to people.
+ vote for the name change
댓글 달기
답변 5개
선택된 답변
Another good test is to boot it, wait for a few minutes, push the power button again, and then push enter. If it shuts off, the problem lies in the display, more specifically the display data cable or LCD panel.
This answer was stolen from Ben Eisenman
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
I've sent in two MBP's in the last month with the NVIDA issue. Just call Support and give them the serial number and they'll tell you if it qualifies.
On one I got nothing on an external, the second I got green strips in the boot up Apple and then it locked. From my first reports to a repaired Mac in hand was 4 days on each one.
good answer +
댓글 달기
I think I found the issue:
http://support.apple.com/kb/TS2377
Symptoms
In July 2008, NVIDIA publicly acknowledged a higher than normal failure rate for some of their graphics processors due to a packaging defect. At that same time, NVIDIA assured Apple that Mac computers with these graphics processors were not affected. However, after an Apple-led investigation, Apple has determined that some MacBook Pro computers with the NVIDIA GeForce 8600M GT graphics processor may be affected. If the NVIDIA graphics processor in your MacBook Pro has failed, or fails within four years of the original date of purchase, a repair will be done free of charge, even if your MacBook Pro is out of warranty.
What to look for:
  • Distorted or scrambled video on the computer screen
  • No video on the computer screen (or external display) even though the computer is on
Specific products affected:
  • MacBook Pro 15-inch and 17-inch models with NVIDIA GeForce 8600M GT graphics processors
o MacBook Pro (17-Inch, 2.4GHz)
o MacBook Pro (15-Inch, 2.4/2.2GHz)
o MacBook Pro (Early 2008)
  • These computers were manufactured between approximately May 2007 and September 2008
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
no, thats a differnet problem - this problem would affect the internal and an external display. normally it is a connection problem or the lcd is toast - but my first guess would also be in the direction of connector/cable
댓글 달기
Thanks for your tips. I tried it but it did not fix the issue.
The laptop works, I mirrored the internal and external screens. Thus I can use it.
But even if I can set the brightness of the internal screen, it does not display anything.
The apple customer care said it is not the NVIDIA issue unfortunately.
They said the screen has to be changed.
Any advice?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
i would always say that you should support ifixit. but that would depend where you're coming from.
use ebay and you will find the right lcd screen that fit's your model
댓글 달기
Hi and sorry to to get it alive again!
I´m from brazil and i´m getting a similar issue.
The problem is that i´ve changed the LVDS cable and the issue continues...
Is there another tip against change the whole LCD Panel?
Tks a lot.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Please start your own question as your issue may be on a different GPU and the answer may be totally different. Thanks
댓글 달기
I have the same problem... I put in a new hard drive with Lion, a new LCD with cables, and its still shows a white screen. But the external is working fine. I even moved all the parts to another Mac, lcd and etc. They worked fine... I'm lost here.. I do get a error saying color profile is incorrect...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
avshalom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 8
전체 시간: 7,669
