주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 질문 전체 보기
SSD instead of HDD
Hi,
My harddisk is stuck. Can I simply replace this old hard drive with a SSD? I read a lot about a dual harddrive/SSD, but is it also possible to have just a single SSD inside it? Every video or repair manual which I looked at always place it at the position of the optical drive as a second drive. If this is possible, where do I connect my thermal sensor?
Kind regards,
Kevin
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
If you're asking can you connect a drive someplace other than at the normal HD SATA port... it's possible - these include an SSD port on the logic board, no matter if you had an SSD as OEM or not, 'but it would be just as much work as to pull the main drive.
However if you had no SSD drive installed OEM there will be no bracket for an after-market SSD.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
info 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 353
