Samsung 46 inch LCD TV takes 3 cycles to power on?
I have a Samsung LN46A550P3FXZA 46 inch LCD TV. Screen shows a cloth-like image until the picture arrives on the third cycle. Capacitors appear fine, no doming on top
좋은 질문 입니까?
좋은 질문 입니까?
Bad capacitor.
해당 답변은 도움이 되었습니까?
I changed the capacitors and the problem is still there
Demetrius White what make and model TV? What capacitors did you change? why? what are the symptoms that your TV has?
My Samsung TV ln46b750u1fxva takes a while to power up the light blinks and then comes back on
해당 답변은 도움이 되었습니까?
If you have replace the caps on the main ps board, then you may need to replace a cap on the controller board…and possibly a chip. For me, it turned out that all I had to do was resolder the 47uf cap. I think over time the joints got “cold” and increase the ESR of the cap. While I bought a kit with the chip and caps, I did not have to use them…just resolder.
Find the MP2363 8-pin chip on the controller board…the cap is next to it.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,954
Bobby, can you explain this "Screen shows a cloth-like image "a bit better. Or post an image of your screen with your question....
oldturkey03 의
