주요 콘텐츠로 건너뛰기
Model A1112 / 512 MB or 1 GB capacity
25 질문 전체 보기
Why only one sound coming from the headphone?
I have iPod shuffle 512mb and recently found that only one sound can be heard via the headphone. After i changed to another headphone, the problem still persist and i suspect the headphone jack is at fault.
How do i change it, does it come soldered with the new board you are selling?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
as you can see in step 11 of the shuffle logic board guide - the jack is soldered to the board.
normally it's only "dirt" inside the jack or one of the contacts is bent. since the headphone jack is "open" - you could see one of those problems when the shuffle is opened.
another possible problem is a proken soldering point/contact between the headphone jack and the logic board. if you have a soldering iron (and are able to use it) - resolder the headphone jack.
good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I too am experiencing this on my iPhone 3GS. I am told to replace the headphone jack. $40 part and an almost extensive tear down. I think I am going to upgrade to ios4 today, erase my jailbreak and try to get a replacement, so I have a working iPod functionality when I upgrade to the iPhone4 and keep this 3GS as a media/gaming system.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I understand that - but i(!) would try to repair it. using the 3gs as an iPod touch would be no option for me ;-)
댓글 달기
귀하의 답변을 추가하세요
Mohd Nadzri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 2,740
