주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Compaq iPAQ Pocket PC 3830. It measures 8.1 cm by 13.3 cm. It was introduced by Compaq in April of 2000. iPAQ was borrowed from Compaq's earlier iPAQ Desktop Personal Computers. The device used a Windows Mobile interface.
The audio volume is not responding to the volume button.
The volume button appears to be in working condition. It does not appear stuck but it is somewhat difficult to maneuver it. It has a hard feel to it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
That sounds like your volume button is jammed. If you unscrew your device you will be able to see what is jamming up the button. It could just be dirt or a screw that needs to be tightened.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Volume controller works on key pad and key pad made up by carbon which disappear after using it and it breaks circuit which is unable to complete your command. In this situation sometime is works and sometimes not and one day it will fully stop.Its really irritate.
Solution-Simply open Sound track button and try to clean it very lightly because if your are cleaning it hardly all the carbon pasted over there will remove it will permanently damage.
After light clean if its still not work simply replace it with new one. Its very easy to change with the help of heat soldering.
http://i00.i.aliimg.com/wsphoto/v0/10380...
이 답변이 도움이 되었나요?
점수 -1
댓글 달기
답변을 추가하세요
Sedina Cavcic 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 14
전체 시간: 408
