주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
Swap SSD between MB Air Mid-2013 with MB Pro Retina Mid-2014?
I have a MacBook Air Mid-2013 (MacBookAir6,2 A1466) SSD with a 256GB SSD and also a MacBook Pro Retina 13" Mid-2014 (MacBookPro11,1 A1502) with 128GB SSD.
I'd like to swap the two SSDs between the two machines. Apparently both machines have the newer PCIe-based SSDs and not the older SATA ones. Does this mean they are compatible (both form factor and interface/protocol)?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Okay, I finally got my Pentalobe screwdriver kit and was able to get into both of the machines.
The 128GB SSD was made by SanDisk and the 256 GB was made by Samsung. The connector and form factors look identical and I was able to make the swap without any physical problems. Both machines booted up with existing install of Yosemite operating system from the other machine, but I ended up wiping and reinstalling anyway just to be sure. So far there are no problems with the swap as far as I can tell.
TL;DR: Yes, PCIe SSD's from MacBook Air Mid-2013+ can be swapped with MacBook Pro Retina Mid-2014. (Not sure when the retina started using PCIe)
댓글 달기
답변 1개
선택된 해법
I see no reason not to try. Both are new enough not to have the older SATA interface as you already know.
While I know Apple has updated the SSD firmware a few times and has at least two sources for the part it will either work or not. If it does please let us know!
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
If this answer answered your question please remember to rate (score) and mark it accepted.
댓글 달기
귀하의 답변을 추가하세요
Collin Ong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 616
