주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
질문 마감됨
Not booting after attempted screen repair
The iPhone 5c I attempted a screen repair. I did not unplug the battery and it was on so I could quickly see if the screen had any issues. I plugged it in and nothing came on while I was diagnosing the problem (I had flickering).
I then thought that the issue was the screen had died, so I tried the original screen. It did not work as well. I panicked, and plugged it into the computer, but it does not recognize it at all.
Did I short it out? Is there any way for me to fix it if so?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
So you could quickly see? it literally takes 30 seconds to boot up. Connect the screen and everything back up and then disconnect and reconnect the battery, see if that works
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
This worked. Thank you. I guess I hit a fuse. I have a problem with white and not black so I wanted to do it quickly. I will be more careful now. I never had problems with safety before so I ignored it and it caused me this problem. Thank you so much
댓글 달기
가장 유용한 답변
You left the phone on so you could quickly see??
That really is not a smart thing to do
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yeah, I need to be more careful from now on. I was tired and wanted to finish it fast and it cost me more time and paranoia.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 91
