주요 콘텐츠로 건너뛰기
Dell Latitude D630 is a thin and lightweight version of the Latitude line. With a 14.1 LCD screen and a 9 cell battery, this laptop is meant to be more mobile.
27 질문 전체 보기
Why does it say contact system administrator or computer manufacture
When I turn it on it shows Windows Boot Manager screen and asks to insert my windows installation disk and click repair.
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem insert disc.
Also has status : 0xc000000e
Info: the not selection failed bc a required device is inaccessible.
Update
Don't have the disk and running Windows 8
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Have you tried to boot into safe mode? Which version Win are you using?
Did a reboot but nothing happened, it crashed on me about 8 mouths ago, well actually it was the blue screen of death so I took it in to a shop and they reinstalled the software
Did it work after they installed the software? Check here http://www.7tutorials.com/5-ways-boot-sa... about how to get into safe mode
댓글 달기
답변 3개
선택된 답변
Do you still have the Windows recovery CD/DVD that came with the system?
If you do all you need to do is insert the disk into the optical drive and let the system fix its self.
If you don't have the disk/s you'll need to contact Dell and order them.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
I faced the same issue with my Lenovo G50. It all started asking me to update where I accepted and left it. It took a day still not updated so I removed my battery and started then it showed me that message in blue screen
Then I did this and it worked..!!!
*Press Ctrl alt delete .....
  • make sure your laptop is connected to WiFi if it is previously connected it will auto connect.
  • then it started autoupdating using my WiFi
  • and finally got updated.
It worked for me I didn't tried on any other laptop .
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I also face to same problem.
I want help to solve same issue.
I have window 10 in my desktop and I have window installation disc(window 8 single language).When insert it in optical drive it not give me option to restart or fix option and error code:0xc0000221
How could I do it? I have Email id for google-yashs5492@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Vanessa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 3,147
