주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2201 질문 전체 보기
질문 마감됨
mic doesn't work on phone calls but works otherwise
It looks like I need to replace a mic on my iPhone 4s, but it looks like there are 2 mics, and I want to buy and replace the correct part.
I cannot be heard on phone calls unless I use the speaker phone. The mic works for other apps. I need to know which part to replace, and I'm looking for a good video on replacing that part.
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
You need to replace the whole charging port assembly with the flex cable, it includes the lower mic, and connector for the home button flex cable. You need to remove and carefully transfer the cover of the old mic to the new one. Here is the iFixit Guide. iPhone 4S Dock Connector Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you so much! This is the link I was looking for!
댓글 달기
You will need to replace the dock connector where the bottom microphone is located. The top microphone is used for noise cancelling and speakerphone, as well as face time. However, you say that the mic works for other apps, does this include voice memo? That should use the bottom microphone also, so give recording a memo a try.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Nope. Voice memo doesn't work either. Thanks for the diagnostic.
댓글 달기
Yes I can make voice recordings. I can cover the mic on the top of the phone and Siri and Google and voice memos still work. People just can't hear me when they call or I call them. I have to use speaker
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Same problem! Mic works with, for example, facebook or whatsapp calls and voice memos, but not when dial or receive calls! Any solutions?
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 2,550
