주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
New screen replacement top left corner doesnt completely flush
I am currently having a hard time fixing an iPhone 5s usually i dont have a problem doing these screens. I have everything set but the top left has the light coming through a little bit and it will not flush like the other parts of the new screen. Help please this is for a customer and i tryed his old screen and it fits perfectly. is it the plastic hinges on top idk please help?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
There are a few things that could be causing this, the most common being frame damage. Is the frame bent at all, any scuff marks near the area not sitting flush? The old screen could have similar damage allowing it to sit flush whereas a new screen would not have this damage, possibly causing it to not seat properly.
Another issue could be the quality of the replacement part. I've had parts where the frame would be lifting slightly, almost invisible to the naked eye and only noticeable after seating the screen. The side of the display frame can flex and catch on the side of the phone's metal frame. Another possibility is that the flex assembly for the front camera and proximity is loose and catching on something as well.
Last possibility I can think of without having it in front of me would be a part that was possibly manufactured outside of the proper specs. It happens a lot on copy grade parts, where the glass isn't cut exactly right or something similar.
So, in closing, check everything to make sure all components are on tight, nothing is falling apart during closing the screen, and lastly try another display assembly.
Good luck!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Richie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 2,485
