주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
iPhone 5c Rear Camera and Flashlight Failure
My iPhone 5c rear camera has stopped working. When opening the camera app the front facing camera works but the rear appears black.
Additionally, when attempting to use the flashlight the icon is grayed out. The flashlight will not start when it is pressed.
I think that I have ruled this out the possibility of this being a software issue. I have rebooted, restored, and update the phone with no change in behavior.
I need to know how the rear camera and flashlight are connected. Do they both connect to the logic board? Is there a sub board that they both connect to?
Should I replace the entire logic board in this case?
I am going to pop the phone open and see what I can see.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 1개
My flashlight and camera light doesn't work. I recently change my screen assembly and the phone/light worked fine for about 2 weeks. Could the replacement part defective? How can I test it? Do you offer any warranty on the parts you sell?
댓글 달기
답변 5개
가장 유용한 답변
the iPhone 5c has 2 separate parts there. the rear camera and the power flex. also known as the upper component cable
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
we remove this ic and replaced with another one and work really good
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My iPhone 5c rear camera and flashlight did not working.so I have no any idea please tell me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
no,just replace the bord terminal surface of the camera ,befor you can fix it back
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Buy a logic board lmao better just buy another phone..
The flash and camera are connected together just replace with a new camera no point jumping the gun thinking it's a board problem.
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
nicholasmanta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 3,519
