주요 콘텐츠로 건너뛰기
The 2005 version of Volkswagen Beetle is the upgraded version of the 1998 edition, which obviously came with a large number of improvements and advanced features.
How to replace headlight bulb of vw beetle 2010
how to replace headlight bulb of rigjht side of vw beetle 2010 convertible.
my car does not working high and lower beam.
I follow the introduction. First, I try replace high beam easily. But I can not relace lower beam. Beacuse, it is difficult to unmount the old lower bulb. Could you show me the way and do I have to change both bulbs. If not, it does not working? Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Other bulbs are held by friction; use pliers to gently pull them out. I cannot understand.
댓글 달기
답변 2개
가장 유용한 답변
There are releases in the engine bay you can turn and pull the whole housing out of the car need to be careful not to rip lens off
How To Install Replace Headlight and Bulb Volkswa…: http://youtu.be/ALcVKiHmn9Q
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Video posted is for the wrong year, they changed how the headlight works after last model refresh. https://youtu.be/Nu8NnjIRGbI
댓글 달기
You will find a small locking lever under the hood and close to the rear edge of each headlight "frame" slide it to the opposite direction in it's "groove" and the headlight and the whole assemble will be able to slide out to change the bulb. Just reverse the procedure to lock them back in.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kiheon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 3,213
