주요 콘텐츠로 건너뛰기
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 질문 전체 보기
Audio Jack Connecting Socket
Hi, I was too rough pulling the audio jack flexi ribbon out of the socket and need to replace the connector on the motherboard but cant seem to find how many pins the connector has anywhere! Are you able to help? Any ideas where to find the info I need please reply :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Hi Kayleb,
The part you are looking for (FPC connector J5501) has 37 pins. This connector is also used on the same logic board for attaching the front panel (i.e. the two identical connectors at the bottom of the logic board). You can order it here.
However, see this earlier post here on ifixit.
Steffen
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Kayleb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 195
