주요 콘텐츠로 건너뛰기
Repair information for the Gaggia Classic Espresso Machine.
19 질문 전체 보기
Espresso Steamer leak repair on Gaggia Classic
The milk steamer leaks when machine is on.
See Item on the right:
https://d3nevzfk7ii3be.cloudfront.net/ig...
It has a tiny washer inside it. I replaced that washer to stop the steamer leaking water and steam at the screw on the join at the washer in the image.
What else could be causing the leak?
I note one part of this Steamer is brass the other chromed material... heating and expanding at different rates?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
The steam valve ("tap") in this machine is a single piece assembly which has a brass-on-brass seal; it can not be disassembled and once it starts to leak the entire valve must be replaced.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi, Take the complete tap house out of the machine, take the tap apart and descale the housing and the parts you find in the tap. In the tap body; check if the seat of the washer is not damaged. crease it and put it back together. You can get machine descaler in the shop (not machine cleaner, but descaler) good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The tap in this machine can not be disassembled.
댓글 달기
no vapor in gaggia baby classica
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
only ligh green no ligh coffee no ligh vapor
댓글 달기
귀하의 답변을 추가하세요
Kevin Sharp 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 2,157
