주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
906 질문 전체 보기
Why is my iPod stuck on the "HP dectect test" screen?
I was following ifixit steps to check the functionality of the hold button (diagnostic). The hold button is working fine (0 and 1). But now my screen is stuck on HP Detect : 0. It says press menu to continue, but when I press menu nothing happens. I have also tried pressing menu twice and several other combinations...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 10
댓글 1개
—me to. have no idea why. it reboots fine -wasn't doing this a week ago.
댓글 달기
답변 6개
가장 유용한 답변
Plug in the headphones (HP).
해당 답변은 도움이 되었습니까?
점수 7
댓글 2개:
...........Hmmmmmmmn? Something about hindsight, and 20x20 eyesight....?!
Thanks!
so i should put my HP laptop away ?
댓글 달기
need to unplug it and then push MENU
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
i plugged the earphones. it says now hp detect : 1 menu to continue. i pressed menu but it does not continue.. can you please help?
any clue please e mail me at bernard_khoury@hotmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
just take out the headphones and press the menu button then BINGO!!!
Now it says 'Accessories Test'
FW_DETECT = 0
USB_DETECT = 1
Please plug FW
What's this mean????
Firewire (FW) connection vs USB connection:
https://discussions.apple.com/thread/275...
Turn off hold button
댓글 달기
If it's not continuing, it didn't pass the headphone (HP) test. Ipods have a little detector that stops the ipod if a headphone isn't detected; it'll pause the song if the headphone jack is removed.
You might want to disassemble it and replace the headphone jack. If that doesn't work, it's probably a bad board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
after plugging it in, unplug it, then it should continue
댓글 달기
I got mine to go to the next stage by clicking the hold switch on and then off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Now it's stuck on FW DETECT : 0
There's no Firewire to plug in, so I can't test this.
댓글 달기
Hello there. I have tried out a solution you your little problem here which was posted by Chi. You see, (HP) is abbreviated for Headphones, which is dumb but oh well, and it worked when my Headphones were plugged in and then unplugged.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
didn't work for me.
댓글 달기
귀하의 답변을 추가하세요
alysont1 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 27
30일 전: 149
전체 시간: 28,814
