주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1001 또는 A1025 / 667, 800, 867, 또는 1.0 GHz G4 프로세서
Swapping CPU between DVI Ti models
Hi
Is it possible to take the 1 GHz CPU out of a DVI Ti and swap it with the CPU in a 667 MHz?
Also other components! Such as the battery, keyboard, optical drive, PRAM Battery etc. I have a mostly working 667 MHz and a mostly working 1 GHz and want to make one fully working machine out of the two! How swappable are the various components in general?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
선택된 해법
I'm using a 667mhz dvi PB with an 867mhz board installed. Works fine, even put in a superdrive from a 1ghz model. I'm not even sure which display I'm using. As long as they're the PowerBook G4 Titanium DVI 667mhz, 800mhz. 867mhz, or 1000mhz, REPEAT! DVI! models! Not the 667mhz VGA or the 1ghz Aluminum models, they're pretty much interchangeable. Some have a bluetooth module (1ghz), others don't. The screen resolution changes some between them, also. So, generally speaking, the parts are interchangeable, just not ALL. Do your homework.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's not possible. However you can swap the 667 DVI with the 800 MHZ motherboard, or the 1 GHz with the 867 motherboard. You can swap battery, DVD drive and RAM memory and keyboard.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Vishy Moghan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 853
