주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
질문 마감됨
iPhone 4: Black Screen and "bong" Tone/Noise
I tried to follow the tutorial to repair my iPhone 4's home button. Unfortunately the process was a failure because I am now experiencing a black screen and a never ending "bong" noise when plugged into a wall outlet.
Can anyone help/provide insight as to what's happened to it and if you think I can fix this, or should I just junk it for parts/repair on ebay? I don't know if this means the logic board has failed...
https://www.youtube.com/watch?v=BR9B-Fye...
Edit: I gave up. I took the whole thing apart and and tried to reassemble and the same thing occurrs. Not worth fixing this phone ($40 for a display really?) so I will be putting it on ebay for parts or repair.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Open back up and make sure the screen connecrors are fully pressed down and seeded correctly if still the same after that you will need to try a new screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks for your response. They are definitely seated correctly - I've reseated them a few times now trying to resolve this (probably only making my chances of getting this to work even worse). So do you think that I destroyed the LCD screen cable? I was pretty careful while I did it and there is no visible damage ie like a cut or hanging cable, so I'm pretty disappointed...
댓글 달기
Try to do a hard reset on the phone... holding home button and power button at the same time.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Didn't work, unfortunately.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 302
