주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20007 질문 전체 보기
Hardshell protectors ok to use?
I just bought a hardshell protector for my MBP, and was wondering if there are any issues with heat dispersion. It does have holes on the bottom for that purpose, and I didn't find anything in the Apple KB on this topic, but I did wonder whether these build up any more heat than normal, and if that has the potential to shorten the life of internal components?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
Get a monitor app which includes a temperature readout (I like iStat but that is purely personal). Run lots of apps on the computer for half an hour or so without the case on and see how hot it gets. I set Chess to play itself and run an app called grapher (in utils) and select a couple of the 3D example, this seems to send my processors to around 100% which should heat up the unit. You guessed the next bit, fit the case and repeat. Does the system get any hotter with the case on or does the cooling work OK.
If all good keep the case.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hello!
Ideally, the bulk of the heat disperses out the vents on the back of the machine (where the fans and heat sink are located). Does the case block these vents in any way? If not, I'd say you're fine. MacBook Pros just run hotter than many laptops, but as long as the airflow isn't impeded, it shouldn't be a problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
rkanes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 919
