주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Black and Decker B2200은 전동 공구, 액세서리, 하드웨어, 주택 개선 제품 및 체결 시스템을 제조하는 미국 기업 Black and Decker에서 생산한 제빵기입니다.
How ro reverse motor direction?
I was given a used once bread machine, a Black and decker B2200, I did try it out and so for it works fine, only one flaw, the mixing container which twist and locks into the mixing coupler comes unlocked while mixing, the mixing paddle counter rotates(anti-clockwise) and unlocks the mixing container, I figured if I changed the direction of the mixing paddle it would not unlock, the color code of the wires going into the motor is black, white and red.
Does anyone know the color code ( i think black is ground) of the wiring? I know from the past most electric motors will counter rotate if missed wired.
Any input would be great, if this machine dies, its ok, just salvage it.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Reverse the white and red. If you have a multimeter, I would test all the wires to make sure.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thanks for the info, I did switch the red and white wire. It changed the rotation from counter clock wise to clock wise, will make a loaf of bread and tell you the outcome, it looks like this was a bad build for this bread maker, the angle of the paddle indicates a right turn, guess quality control was asleep.
Thanks
의 공유
I didn't get my loaf yet ;-)
의 공유
댓글 달기
답변을 추가하세요
marc 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 3,753
