주요 콘텐츠로 건너뛰기
11인치 디스플레이가 장착된 MacBook Air 모델에 대한 수리 안내서, 지원 및 문제 해결 정보입니다.
929 질문 전체 보기
질문 마감됨
Dented Aluminium Case Replacement
Hi,
I have MacBook air 11.6" which is working properly, my problem is my MacBook was fall down 3, 4 times and it badly dented around the body.
I want to change out the body shell Is it possible?
Please replay, thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Your best bet is to locate a water damaged system which has an unblemished body. Then strip it down and swap out your working parts into it.
While this is possible it does have risks! First are you skilled enough to do this? Are the parts you can't replace still working?
This is not something I would attempt if you've never worked on MacBooks. You may end up just making a big costly mess!
As an alternative why don't you look at getting body covers. Many look dam good! We apply an adhesive version which has our graphics & logo (less likely to be stolen).
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 856
