주요 콘텐츠로 건너뛰기
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
door does not open to put game in.
I can not get the original xbox door to open otherwise works fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
How do i Fix It ?
Hey mate, the method of fixing it, is bellow in answers section.
댓글 달기
답변 2개
가장 유용한 답변
Hey mate, this is a common problem with the original Xbox, due to their old age. Its due to a rubber belt in the disk dive stretching or braking. You can either fix the disk driver, by obtaining a new belt, or replacing the disk drive.
This tear down will show you how to open up your Xbox;
Xbox Teardown
and these links will tell you in detail how to fix the disc driver, if you wish to;
http://www.ebay.com/gds/Xbox-Repair-How-...
http://www.gamefaqs.com/xbox/915780-xbox...
hope this helps you mate.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
I've had the same problem before and it was indeed the disc drive belt.- I've actually found that is typically the problem
댓글 달기
I had this same issue and i fixed it.
But it is a rubber belt that needs to be cleaned.
Use a paperclip to Manually reject. You will see a small pulley and a bigger one in the middle gap of the cd tray.
Use tweeters to take the belt out.
Use a damp paper towel to clean any dust/dirt from the small rubber belt.
Then carefully put the rubber belt back on.
Turn the system on...
This has fixed 2 system for me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jjelinski 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,684
